Discrete locations for AFR gauges and boost gauges
Old 07-24-2011, 11:28 AM
s2konroids's Avatar
Default Discrete locations for AFR gauges and boost gauges
I have a pillar pod housing 2 gauges, but it screams the car has been modified. I'm looking for something a bit less revealing and out of the way, where have you guys put yours?
Pics if possible.
Cheers
Old 07-24-2011, 11:59 AM
JawKnee's Avatar
PLX DM-100 multiguage. Currently monitoring AFR, and boost/vac on this single gauge.
Old 07-24-2011, 12:04 PM
DFWs2k's Avatar
radio door
Old 07-24-2011, 12:10 PM
s2konroids's Avatar
Nice,
thanks guys.
Old 07-24-2011, 02:02 PM
EternalLx's Avatar
Old 07-24-2011, 03:44 PM
NH_s2k_Guy's Avatar
Unless you're putting gauges on for show, you want them somewhere where you can see them easily
when you are pushing the car the hardest. I was going to put mine in the radio door but you have
to look down to see them, and that could be bad if you are at WOT.
Old 07-24-2011, 04:13 PM
DFWs2k's Avatar
if you're WOT you shouldn't be looking at anything other than the road in front of you, imo
Old 07-24-2011, 04:19 PM
GrandMasterKhan's Avatar
Hidden Gauges FTW
s2krayz (08-06-2020)
Old 07-24-2011, 04:39 PM
camuman's Avatar
Gauges do nothing to worn u wot. Logging helps with that. Gauges are nice to see max boost or air temp or water temp or knock. U just can't pay attention to them when wot.
That being said radio door is best for discrete and a pillar is easiest. I went easy lol. Two serial gauges in a pillar. One stays on o2 and the other usually on iat.
Old 07-24-2011, 04:42 PM
metros's Avatar
Are all gauges mounted on steering column custom mounts? I haven't seen anything available for our cars to mount a gauge to the steering column.
Quick Reply: Discrete locations for AFR gauges and boost gauges
