Do I have enough room to remove my Pulley? (PIX)
Old 07-28-2012, 09:28 AM
EOE
EOE's Avatar
Default Do I have enough room to remove my Pulley? (PIX)
I am am thinking of swapping my pulley and was told the blower has to come off. After searching around people said not always... Do you guys this is enough room?
So far this thread is saying the AP1 pulley is too large, I actually have a 4" pulley, so maybe I'm okay?
https://www.s2ki.com/s2000/topic/528...ng-new-pulley/
Old 07-28-2012, 02:25 PM
jordannn93's Avatar
When I did mine on the ct kit 4.25" to 3.8" I just loosened the bolts that hold the sc on and I was able to pull it off.
Old 07-28-2012, 03:04 PM
Deception's Avatar
i was able to remove the pulley with everything mounted for the 4.2" pulley.. but going from the 3.8" to 3.4" I had to take the S/C off the car.
The problem is not the space in front of the motor but being able to wedge something under the pulley to loosen it.
Old 07-28-2012, 03:27 PM
99SH's Avatar
It'll come off, make you you have a nice long prybar. The pulley won't simply slide off.
I've replaced my 4" pulley with a 3" and now a 2.8" with the blower in place. If you need a hair more space, you can undo the top left bolts on the mounting plate and pull it back a tad.
Old 07-28-2012, 10:03 PM
s2000Junky's Avatar
Loosen the pulley first with your belt wrench, then back out the SC mount plate bolts far enough for you to clear the head.
Old 07-29-2012, 06:32 AM
EOE
EOE's Avatar
Thank you for the response guys! Will give it a go after I figure out my idling/tune issues. Sigh
picco97
05-16-2016 10:14 AM
BahrainONE1
09-12-2005 06:58 PM
Diddy
06-05-2002 04:16 AM
Quick Reply: Do I have enough room to remove my Pulley? (PIX)
