Do i need a Peak and Hold driver?
Old Jul 12, 2007 | 07:28 PM
SPECIAL-OPS-S2K's Avatar
Default Do i need a Peak and Hold driver?
I'm VERY close to going turbo and am buying the last items I will need before i do the install... gauges and such... I have decided on the Defi BF gauges. I have an AEM 1052 and want to buy the 6 in 1 Wideband Gauge controller unit is there any helpful info in setting this up or installing it that anyone could offer? I want to put it on the left side of the wheel where the remote stereo controls are located... also I have seen lots of setups on here mention they are using the AEM Peak and Hold injector driver? What is this and what are the pros to having this over not? How does it work and do you need a different type of injectors to work with it? Lastly I want the AEM to control my boost so I know I will need the AEM or GM boost sensor, which do you suggest and what else will i need / how will i set this up with my 1052?
Thanks for the help!
Old Jul 12, 2007 | 08:15 PM
squirrels2k's Avatar
pm'd you
Old Jul 12, 2007 | 08:17 PM
NFRTurboTerror's Avatar
Are your injectors Saturated or Peak and Hold?
Old Jul 12, 2007 | 11:36 PM
AusS2000's Avatar
You only NEED a peak and hold controller if your injectors are peak and hold.
As for boost solenoids, definitely the AEM. The GM is ok but not known for reliability. And if it losses power it defaults to wastegate closed rather than the falling back on the spring.
Old Jul 13, 2007 | 04:45 AM
so is there a benefit of having peak and hold injectors over regular ones?
Old Jul 13, 2007 | 05:23 AM
PeanutButter's Avatar
Not unless you have peak and hold injectors. Its basically taking the place of a resistor box.
If you have saturated, they are plug and play, no harness is even required
Old Jul 13, 2007 | 07:51 AM
snakeeater's Avatar
P&H injectors have one big advantage over saturated coil injectors. The p&h injectors provide better resolution to control fuel flow across a wide operating range. Many factory turbo cars use p&h injectors to meet the wide range of fuel flow rates. Another way to increase resolution is to use multiple smaller injectors.
The downside is cost. Since our stock injectors are saturated, you can't just replaced them with p&h injectors. You must also buy the p&h injector driver to make them work.
The injector is basically a valve. But it pulses on/off with duty cycle (% of time spent open) called out from the pulsewidth values in the cells of the ECU. The injector is asked to accurately flow a tiny trickle of fuel at idle. But at the other extreme, it must provide lots of fuel flow to make lots of horsepower. If you get large saturated coil injectors (to reach high HP level) they will usually have a poor idle.
Do some more research. The internet has tons of information.
Old Jul 13, 2007 | 02:24 PM
I'm most likely going to be running 750cc-880cc injectors... so for injectors of this size would it be worth the money to invest in the P & H and get the P & H injectors?
Old Jul 13, 2007 | 03:50 PM
Spec_Ops2087's Avatar
I believe 880cc+ are peak and hold injectors.
Old Jul 14, 2007 | 07:23 PM
snakeeater's Avatar
Yep, I believe the largest saturated coil injectors are 750cc/min.
