Do i need a retune?
Old Oct 15, 2010 | 01:55 PM
azride1983's Avatar
Default Do i need a retune?
i recently bought the litespec exhaust 70mm today and i'm planning of adding a testpipe or HFC. will the reflash be affected by the changes? like the AFR? do i need a retune for only this additional mods? thanks..
Old Oct 15, 2010 | 02:06 PM
hentaiboy22's Avatar
This is in the wrong forum topic
Old Oct 15, 2010 | 02:21 PM
madcowdk's Avatar
try here...
https://www.s2ki.com/forums/index.php?showforum=193
Old Oct 15, 2010 | 02:51 PM
Dark_Sub_Rosa's Avatar
Moving to forced induction
Old Oct 15, 2010 | 05:11 PM
Elroy's Avatar
IF you are running a re-flash you will thin the tune a bit which for me was a good thing. I would recommend getting a FlashPro (if you don't already), log it, and post and/or send it to a tuner. Jeff Evans and Elite do e-tunes and you place the af's where they should be for your S.
J
Old Oct 15, 2010 | 06:57 PM
camuman's Avatar
def log it. changing those parts could potentially cause the car to run lean. not def, but potentially.
Old Oct 15, 2010 | 07:29 PM
stitos2k's Avatar
If your using the tune from kraftwerks you'll probably pickup a decent amount of whp if you get retuned.
Jtballaa87
Jan 2, 2012 12:25 PM
chicag0t
Oct 13, 2008 06:44 PM
cloud_9
San Diego S2000 Owners
42
Apr 5, 2008 01:25 PM
gotswap
May 26, 2006 06:59 PM
