Do you need a very efficient intercooler?
Old Jul 18, 2005 | 03:18 PM
Sideways's Avatar
Default Do you need a very efficient intercooler?
The pressure drop with this system is around 1 lb total. I held one in my hand today and the construction is fantastic. Check it out:
http://di.se/Nyheter/?O=Index&page=%2fAvde...2%26pressCp%3d2
http://www.alertmotorsport.com/laminova.htm
http://www.textiform.se/1Intercool_21apr.pdf
Old Jul 18, 2005 | 05:08 PM
Slows2k's Avatar
Laminova's are used by several OEM manufactures (Ford and GM) A good friend of mine has been trying to get a 4 core box to use on a Centrifugal SC'd B20.(T-trim Vortech) unfortunately, Hytech and some of the other distibutors can't get them at this point.
They are very efficient, and easy to package.
Old Jul 18, 2005 | 07:42 PM
Ztec's Avatar
Very Promising - I wonder how it would work in place of our coolers and if it is adaptable with our existing cores and pumps from the Comptech or Vortech units?
Old Jul 18, 2005 | 08:40 PM
Slows2k's Avatar
The pumps will work just fine, but you'll need a larger heat exchanger/radiator than either comptech or vortech provides.
Old Jul 19, 2005 | 05:06 AM
Ztec's Avatar
I am looking into using a 25 row Mocal unit for my comptech cooler because I am using one for my oil cooler and I have this little problem with things being symetrical so, Ideally I would want the two coolers side by side in front of the A/C and radiator. Would that be sufficient to use with this system?
also, what do these bad boys cost????
Old Jul 19, 2005 | 05:44 AM
Sideways's Avatar
I don't have an answer about the capacities but the cost starts around $1500 and goes up with modifying. This would be great on a racecar or anyone with much higher (20+ lbs) boost.
Hytech makes enclosures with custom aluminum extrusions and o-rings. No welding to break on the body of the unit. They are tested to 50# for leaks.
Old Jul 19, 2005 | 02:59 PM
Slows2k's Avatar
The radiator/heat exchanger Hytech reccomended is about 1/2 the size of the S's stock radiator.
unfortunately, Hytech hasn't been able to get the boxes lately.
A7DY W
Feb 28, 2007 09:29 AM
ItalianBucwheat
Mar 19, 2004 06:36 PM
Yellow Streak
Oct 15, 2002 11:53 AM
ken reich
May 30, 2002 03:49 AM
