View Poll Results: Do you coat these parts
Thermal coating on turbo housing
50.00%
Thermal coating on exhaust manifold
75.00%
Thermal coating on downpipe/midpipe
62.50%
Thermal coating on piston tops
25.00%
Thermal coating on combustion chamber/valve faces
0%
Thermal coating on exhaust port
0%
Friction coating on piston skirts
25.00%
Friction coating on valve stems
0%
Oil shedding on crank, rods, cylinder block
0%
Heat emitting on radiator, oil coolers, intercooler
12.50%
Multiple Choice Poll. Voters: 8. You may not vote on this poll
Do you use coatings in your engine?
Old Apr 28, 2018 | 10:31 PM
DavidNJ's Avatar
Default Do you use coatings in your engine?
Lots of engine parts can be coated. This is from a post on a Supra forum:
I had [Swaintech] white lightning coating put on for my downpipe, manifold and heat shields, and TBC put on the combustion chamber, exhaust ports and valves. The white lightning stuff is ridiculous, underhood temps are down a lot and I'm no longer worried about burning myself on anything in the engine bay. After a few hours of driving, I can touch the downpipe for a second or two and not come close to burning myself.
I love my ceramics in my car... Back in 1998, when I built my engine, that I am currently running today... I coated the top of my pistons, bottom of my valves, exhaust header and turbo housing, Intake runners and upper, valve covers and etc. All Black or Polished, to dissipate as much heat as possible.
Another thing I did while at the coater, I had them moly coat the side (skirts) of the pistons and valve stems... My car runs between 50-60F degrees cooler than most other MKiv cars with similar setups (750whp)... I also have over 45k miles on motor. No oil burn or compression loss.
I have always been a supporter of Coatings especially Ceramic and Moly.
There are many coating options. For a car with forced induction, there is obviously an advantage to coating the turbine housing and exhaust manifold; it is offered with nearly every turbo kit. Coating the downpipe can also keep heat out of the engine compartment. Coated bearings and piston skirts are often done to reduce friction. Thermal coatings keep heat out of the pistons and cylinder head both putting both more energy in the combustion and less in the coolant. Coated intake ports can reduce heat transfer to incoming air. Coatings can also be applied to engine blocks, and piston undersides to assist in oil return. There are coatings that improve heat transfer that can be applied to intercoolers, radiators, oil coolers, and brake calipers.
There are many companies that do this. This is Swaintech's descriptions of their coatings: Race Coating Descriptions | Swain Tech Coatings | Industrial Coatings | High Performance Racing Coatings. This is Techline, which supplies coating firms: https://techlinecoatings.com/tech-li...gine-coatings/. This is Polydyn's descriptions: http://www.polydyn.com/
Mahle pistons ship from the factory with a thermal top coating and a friction skirt coating.
Do you use coatings?
Old Apr 29, 2018 | 05:44 AM
JUSTINTHECOASTIE's Avatar
Interesting. Another question to ask is how long is the stuff suppose to last and if it lasts
Old Apr 29, 2018 | 07:15 AM
Charper732's Avatar
Ceramic coating never goes away unless your physically damage the part.
There are different types on piston skirt coatings. Many of them are just break-in coatings. Majority of the ones ive seen like on weisco and the like will wear and show base metal of the piston. Swaintechs is a lot thicker.. up to .0016" if i remember correctly. Both serve a similar purpose, reducing friction.
I have a set of CPs out at swaintech now for ceramic tops and pc-9 skirts
Old Apr 29, 2018 | 10:56 AM
Anything that involves friction causes wear or a breakdown of some sort sooner or later. I am very curious in this, and wonder what racing teams using this technology and on what items they apply it too
Old Apr 29, 2018 | 01:04 PM
DavidNJ's Avatar
Calico says (https://www.calicocoatings.com/company/coating-faqs/): "Calico's CT-2 ceramic thermal barrier and CT-5 oil shedding, corrosion resistant coatings are virtually permanent.
Calico's CT-1 and CT-3 dry film lubricants are "sacrificial" in nature and eventually wear out. But rather than wearing out the engine part, the coating absorbs the wear — saving you time and money on expensive engine parts. It is also possible to re-coat and further extend the life of the coated parts at a fraction of the replacement cost (i.e. pistons, etc.).
PVD/PECVD coatings are highly corrosion resistant and virtually permanent. It has been proven that the actual part will wear out long before the coating does. These coatings extend your tool/part life and can help your company realize significant savings in replacement costs and in helping your mean time between occurrences."
The descriptions of their coatings are here: https://www.calicocoatings.com/coatings/. Another article on the topic is here: Scratching the Surface: Coatings and Treatments for Engine Components - Engine Builder Magazine
Note: many classes of racing have specific rules on what can and can't be coated. Many S2k FI cars have the intake in the engine compartment, probably making them more sensitive to heat reduction. While none of the S2k cars here seem t have worked on this, heat management (making less from reduced friction and pushing more to the exhaust rather than the coolant) can result in the cooling system creating less drag and allowing more downforce.
Old Apr 29, 2018 | 01:43 PM
illestrolla's Avatar
I had my last manifold coated with Swaintech White Lightning, and will be coating my new one with it immediately as well.
Old Apr 29, 2018 | 03:26 PM
Spoolin's Avatar
I've used Jet Hot on my old LoveFab GT1 manifold and it helped a ton with under hood heat.
Old Apr 29, 2018 | 04:24 PM
MARK AUS S2K's Avatar
Has anyone Ceramic coated their turbo housing and use a Turbo Blanket over the top?
My engine bay is still bloody hot even with the Ceramic Coating (Black 2000 degree) so I am about to buy a PTP or DEI Turbo Blanket.
Old Apr 29, 2018 | 04:45 PM
DavidNJ's Avatar
Do you know whose coating was applied? The Swaintech White Lightning (~.015" thick) and JetHot Extreme 2500 (.006-.013" thick) are both white-whitish but can be painted. I wonder if the black coatings are thinner.
Old Apr 30, 2018 | 07:02 AM
yamahaSHO's Avatar
I've used SwainTech and regular ceramic... I don't do that anymore as I don't think I really does much but lighten the wallet. I'll use cheap local ceramic if the hot side is not stainless and can rust, but then follow up with a turbo blanket. On the pipes, I like to use Inconel shielding to control heat in the engine bay.
