Does this look right?
Old Aug 24, 2011 | 06:55 PM
D1sclaimer's Avatar
Default Does this look right?
I ordered some sleeves from AEBS for my machinist to install and got them today. Is one supposed to be different? There is also a small ding out of another one on the top outer part of it. I don't think the ding is anything to be alarmed about, but what about the different sizes? I was gonna call AEBS tomorrow, but wanted your guys thoughts incase I am an idiot and it is right.
[sub]This is the oddball one with the ".003 Taper," on it[/sub]
Here is the ding.
Old Aug 24, 2011 | 07:24 PM
EVLS2K's Avatar
I am not an expert but i dont think so, actually i am sure
Old Aug 25, 2011 | 04:25 AM
Spoolin's Avatar
The ding will be machined off when they are put into the block and surfaced to match the deck height, but the one being that much longer may be a mistake and I'd find out why its like that. Are the bores the same diameter? It may just be that they all also need machined on the lower side to get the to the correct length for the block bore to lock them in and a good machinist that does your work will know this. They all may be off a bit and just the one is more excessive than the rest, but when they all get machined down on the lower end to match up the length of the block bore, they will all be where they are supposed to be and again, a good machinist you chose will know this. It could also be possible that one needs to be a bit longer to sit down in the block a little more, but I really don't know. Those are just my oppinions, but you should call AEBS to confirm.
Old Aug 25, 2011 | 08:38 AM
D1sclaimer's Avatar
I gave them a call and they are all supposed to be the same height. So far it seems like I am gonna be taken care of after he gives me a call back.
Old Aug 25, 2011 | 09:17 AM
siadam's Avatar
I'd agree.
FYI, if your having someone else do the work, make sure you give them your girdle too. It needs to be tq'd down when they do a bore on the cylinders to keep them true.
Old Aug 25, 2011 | 10:08 AM
D1sclaimer's Avatar
Originally Posted by siadam
I'd agree.
Yep, and I bought some of the custom batch of ARP main studs from InlinePRO so we can line hone it and do all this as well.
Ludeboye1
Aug 21, 2011 09:37 PM
pikkashoe
Nov 7, 2005 01:56 PM
Stratocaster
Dec 31, 2002 11:46 AM
BlueHS2000
Aug 23, 2002 11:21 AM
Kwando
Jun 4, 2002 06:37 AM
