Draining Fuel in tank?
Old Apr 24, 2009 | 11:59 AM
siadam's Avatar
Default Draining Fuel in tank?
I was under the car last night, didn't see a drain plug like on civics.
I have some fuel that was sitting in there since Oct of last year. Fires up ok, but I want fresh fuel for my tune.
Not quite 1/2 a tank I need to drain
Thoughts?
Old Apr 24, 2009 | 12:08 PM
dsddcd's Avatar
Pull off the supply and cycle the pump.
Old Apr 24, 2009 | 09:17 PM
neeman77's Avatar
Yea that is the only way, there is no drain on this fuel tank.
Old Apr 24, 2009 | 10:58 PM
SgtB's Avatar
Siphon it out the neck.
Old Apr 25, 2009 | 04:42 PM
siadam's Avatar
Gas neck = fuel fill up ?
Old Apr 25, 2009 | 06:36 PM
Sellout's Avatar
Your 05 should still have a return style fuel system, you can remove the return line from the FPR, and run a hose from the barb on the FPR down to a gas can and start the car. Then you just let it idle until it dies...
The fuel that would be going back to the tank from the FPR is now dumping into your gas can. I've done it this way, it's easy as hell, but takes a little bit of time. If you know a way to make the fuel pump run then it's faster to disconnect the supply to the FPR and run that to a gas can and start your fuel pump.
Old Apr 25, 2009 | 06:53 PM
Slows2k's Avatar
Or you could drive the car at low speed and burn off the old gas and not have to do any extra work
TonysMI4
Aug 29, 2011 10:10 AM
TonysMI4
Aug 28, 2011 11:21 AM
joefish1298
Jul 21, 2010 06:15 AM
Ink01
Jul 23, 2006 08:19 AM
