dry nitrous
I'm going with a 50 dry shot kit which basically all I have to do is plug and play. But since its dry, and I spray before the map/maf sensor will the ecu pick up the n2o and compensate fuel with the stock ecu?
I pointed it out not to lay blame. Only to inform you that it happened. It's a delay in the way the site works based on your browser. You most likely clicked it 3 times when you were waiting for it to load. You just have to be patient and not click it again if you don't see something happen right away.
You can go to each of those other threads and delete them yourself using the admin options at the bottom of the page. The thread starter can do this. (I think.)
