Dyno Numbers
Old Dec 7, 2007 | 05:13 PM
  #41
smirfs2k05's Avatar
Lets go up to hesperia theres a dynojet up there 50 bucks for 2 pulls or 55 for an hour.
Old Dec 7, 2007 | 06:04 PM
  #42
Spec_Ops2087's Avatar
Originally Posted by Enthralled,Dec 7 2007, 05:16 PM
I went to church a little over a month ago and he said on his stock s2k his dynapak read 212whp, but on a dynojet it read 202whp.
I've hosted 3 dyno days, a stock AP1 dynos around 195ish but yes all dynos are different and ~200 is within dyno error of 195
Either way, a dyno pack does not measure flywheel horsepower, the only way to do that is with a giant engine dyno. A dynpack reads rear "hub" horsepower. I don't say rear WHEEL horsepower because you must dismount the wheels to measure using this device. It will lead to a slightly higher number due to the horsepower loss of the rotating wheels is not calculated.
Old Dec 8, 2007 | 12:57 PM
  #43
Enthralled's Avatar
btw how many psi did Shawn say he was seeing?
Old Dec 8, 2007 | 01:02 PM
  #44
chairmnofthboard's Avatar
On my car??? 7 PSI.
Old Dec 8, 2007 | 01:04 PM
  #45
Enthralled's Avatar
Originally Posted by chairmnofthboard,Dec 8 2007, 03:02 PM
On my car??? 7 PSI.
you do have a factory freak then...I was at churchs place a bit over a month ago andd he said he saw 7.7psi and i got 358whp/236.9tq.btw i just have a test pipe and a clutch.
I'll be going back to church sometime in january to get my 4" pulley tuned.should yeild about 10 psi and i should be over 400whp.
Old Dec 8, 2007 | 01:15 PM
  #46
4" is 12.5 PSI
So you're getting 358hp/236 on the factory pulley? what's your redline?
Old Dec 8, 2007 | 01:19 PM
  #47
oooh i just realized you have an AP2. should be about 10 psi.
Old Dec 9, 2007 | 07:24 AM
  #48
S2Kart's Avatar
Dynapack vs Dynojet
Old Dec 9, 2007 | 08:34 PM
  #49
batikan's Avatar
go to another dyno and see what happens. chuches dyno always read way high.
if i were closer, i would just go there for the heck of it to break into 500+ on pump
Old Dec 10, 2007 | 10:21 AM
  #50
Like I said a numerous times. Pay for the dyno, and I'll take it.
