E-manage ultimate
Old Oct 20, 2005 | 10:42 PM
infinitys2000's Avatar
Default E-manage ultimate
Hey Everyone,
Just wondering if anyone has installed the E-mange ultimate?
I purchased the PnP harness from Boomslang Fabrication.
I need to know what the internal jumper settings are.
Here is the pic of the options.
This is what settings i have.
JP1 OPEN
JP2 OPEN
JP3 OPEN
JP4 OPEN
JP5 OPEN
JP6 OPEN
JP7 1-2
JP8 2-3
JP9 OPEN
JP10 2-3
JP11 OPEN
JP12 OPEN
JP13 OPEN
JP14 OPEN
JP15 2-3
JP16 1-2
JP17 OPEN
JP18 OPEN
JP19 1-2
JP20 1-2
I'm pretty sure it is correct, But the Engine light still comes on. I will post the error code soon.
Error is Air Pump Motor Voltage high, which should be P1416 "Air Pump Electric current sensor circuit high voltage"
How can i fix this???
Any help would be appreciated.
Chris
Old Oct 21, 2005 | 04:32 AM
Slows2k's Avatar
I don't see anything the E-manage wires into for the airpump. Check your jumper harness for broken pins, and that all the wires go from one side of ther harness to the other in the correct pin location.
Old Oct 28, 2005 | 05:26 AM
I figured out the problem. US ecu and AU ecu different.
Harness i bought is for US ecu.
Anyways, do people think the jumper pins are ok.
Old Oct 28, 2005 | 04:22 PM
Slows2k's Avatar
Moving to FI.
Folex 187 has his Ultimate e-manage settings here:
https://www.s2ki.com/forums/index.php?showtopic=331737
Old Oct 28, 2005 | 08:06 PM
folex187's Avatar
Don't connect your emanage to the coolant or intake air temp wires. It will cause your car to act crazy.
fireball
Aug 26, 2010 03:28 PM
Chris S2K
May 19, 2010 09:20 AM
dwedge
Feb 13, 2008 07:02 AM
S_NeWb
Sep 16, 2007 08:26 PM
infinitys2000
Oct 20, 2005 11:02 PM
