E85 Target AFRs ?
Old May 29, 2014 | 09:18 PM
jpetch05's Avatar
Default E85 Target AFRs ?
Put the car back on E and ran some logs. 16 lbs I'm running between 11.40-11.60 AFRs.
Checked my logs from last year and at 23 lbs I was in the 10.50s range. On this same 23lb log I was mid 10s afr (for those split seconds until I hit my target boost) from 14lbs on up until it hit 23.
I did have a fuel filter issue last year, changed it and all was well.
Some details with E I question including this topic. I was always under the impression you wanted to be on the rich side with ethanol. But I'm unsure what my target afr is for 16lbs of boost compared to 23. I am worried to be mid 11s on E at 23 lbs of boost so I didn't keep cranking it up until I asked you guys.
Anyone any input ?
Old May 30, 2014 | 05:57 AM
yamahaSHO's Avatar
Mid-11's (gas referenced) is ideal on E85 and boost.
You do run more physical fuel with E85, however, when lambda is converted to a gas scale, you can actually run E85 leaner than gasoline. I generally target around 11.5:1 on E85 with Subaru's (many will run it up to 12:1). You could probably lean it out to 14:1 without knock, however, you'll lose power and your EGT's will climb high.
Old May 30, 2014 | 06:22 AM
jpetch05's Avatar
Thank you sir
nguyen365
Jul 4, 2017 05:37 PM
s2kseven
Mar 4, 2013 06:11 PM
RedLineS2k10
Oct 17, 2010 05:47 AM
blackey
Jul 27, 2007 08:21 AM
VisualEchos
Dec 9, 2002 07:30 AM
