easiest way to replace bolt on turbo housing.
Old Jun 20, 2007 | 10:30 AM
ChefJ's Avatar
Default easiest way to replace bolt on turbo housing.
anyone have any pics of replacing the bolts. Specifically the bolt directly below the turbo housing. Is it really going to be that difficult??
Old Jun 20, 2007 | 06:08 PM
ChefJ's Avatar
Well I found out there is no easy way. I took off the wastegate and unbolted the downpipe. took the vacuum hoses off and removed the first charge pipe. Then loosened the exhaust manifold but couldn't get the turbo and manifold out because the turbo was to large to fit so I had to remopve the housing and then slowly slide the whole thing out. Doesn't sound like much but when you can't get a socket to half of the bolts you have to use wrenches at weird angles and without a lift its a full days work.
jtins2k
Dec 16, 2011 12:00 PM
H4RD ON
Feb 22, 2011 02:49 PM
rsmatti
Jun 30, 2010 08:05 PM
Deception
Jun 23, 2010 12:24 PM
AusS2000
Feb 11, 2010 09:04 PM
