EBAY Turbo Kit?
Besides a dozen other problems with the kit, look where the hole for the stud is on the second runner below. It's no where near where it should be.
It also says ** our kit comes with a cast iron manifold, unlike other sellers who have stainless steel which will crack and break!** - That certainly does not look like cast iron to me (or tha actual manifold you will get)
i saw the same thing you guys saw...
BTW, that manifold is the OBX copy of the Full-race Gen-1 tubular manifold. You can buy it off of ebay for 350 with shipping. That blow off valve is an hks clone for $50, and the intercooler and tubes are generic (150) and do not fit the S2K without cutting!
The turbo is also a generic ebay t3/t4 ($250) that will probably come apart and spray your motor with lots tiny bits of metal, the first time you open it up on the dyno!
If you spec'd this out individually from ebay, it would come to about 800!
Don't touch it with a 50 foot pole, Unless you really want to throw away your money. In which case, give me the money instead!
