ECU options
The largest advantage to the AEM EMS is the abilty to plug into and interface with the stock wiring harness and sensors. I know to use a Motec ECU will cost 3X the AEM just in wiring it all to work.
Originally Posted by buzilanga,Mar 17 2005, 08:56 PM
You do have a point there, but will you extract the good juice out of the FI engine with the AEM? How good it this ecu, and did they fix the prob with the water temp?
Originally Posted by Sideways,Mar 18 2005, 12:18 AM
"They" didn't fix the temp but Modifry here on S2KI developed a device that allows the temperature gauge to work. The parameters are programmable.
How much to get this from Modifry?
Spoolin, Modifry's mod is a module that intercepts the signal from the ECT sensor and outputs a modified signal to the dash. So it actually bypasses the AEM ECU and allows you to set which bars light at what temperature. Go to Modifry's Website for more info.
