aim solo dl and aem ecu
Old Mar 18, 2014 | 08:45 AM
sebian's Avatar
Default aim solo dl and aem ecu
hi guys
recently bought aim solo dl and they provided me with a cable to connect to the aem ecu via rs232
made the changes required to the ecu
cannected the cable to aim solo but nothing!
is there anything else i need to do to the ecu to start transmiting ecu data?
cable is fine talked to aim!
aim solo dl works fine!
if the there is anyone with the same set up any advice would be usefull!
here is the pdf to make the connection..http://www.aim-sportline.com/downloa...19_106_eng.pdf
Old Mar 18, 2014 | 01:55 PM
sebian's Avatar
problem solved!!
thanks aem!
Old Mar 18, 2014 | 02:43 PM
Stratocaster's Avatar
Originally Posted by sebian
problem solved!!
thanks aem!
I will bet you had to turn on the serial data stream IIRC. I had to do the same thing for my DL1
Old May 30, 2014 | 11:27 AM
s200059's Avatar
problem solved!!
thanks aem!
I have the same problem with my setup . What did you do to solve it ?
Old Mar 4, 2015 | 04:37 AM
sebian's Avatar
hi guys back to 0 again....
can anyone remind me how to enable data stream in the aem ecu?
did everything again cause i changed calibration and i just can't make solo and aem connect again!
Old Mar 5, 2015 | 01:03 PM
thepoi's Avatar
What'd you do last time to make it work?
Old Mar 5, 2015 | 03:29 PM
sebian's Avatar
haha....it took me about 4 hours but found it...
it's setup-telemetry-telemetry wizard-enable
in this way the ecu starts streaming data!
Blucky87
Jul 18, 2011 12:20 PM
s2konroids
Aug 31, 2009 11:31 PM
mys2k3
Mar 29, 2009 06:57 AM
REV_29K
Mar 1, 2005 10:12 PM
