ECU pin
Old Nov 6, 2012 | 06:07 AM
liquidgsr's Avatar
Default ECU pin
I am trying to install my pin for my B16 for the Boost solenoid. I got some pins from a friend and it seems like it doesn't fit all the way through. Is there a certain way they fit in or is it just hard to get into the stock harness? Is there any other way of running a wire to the boost B16 pin on the ecu?
Old Nov 6, 2012 | 06:27 AM
gettin it's Avatar
B16 or D16?
Old Nov 6, 2012 | 06:28 AM
liquidgsr's Avatar
B16. I have a MY07.
Old Nov 6, 2012 | 06:30 AM
gettin it's Avatar
Awa! ok.
Old Nov 6, 2012 | 02:12 PM
Manny2587's Avatar
https://www.s2ki.com/s2000/index.php...t__p__21974130
Reference this thread. I finally found the correct pins for 06+ harnesses. Took me a while. I will try to get some pins for you, just mailed out my last 2.
Old Nov 7, 2012 | 04:28 AM
liquidgsr's Avatar
Yeah that is what I was looking at. The ones I have must be bigger.
Old Nov 9, 2012 | 04:47 AM
miguel329's Avatar
that link is what i followed for my order, its for 00-05 wont work for our cars...pins dont fit correctly... anyone know what pin 06+ need?
Old Nov 9, 2012 | 08:17 AM
liquidgsr's Avatar
Is there anyway to pull one of the factory pins out? I have the ELD cut off and running to the wideband and have some wire and the pin still attached to the wiring harness. If I can somehow pull it out I can use it.
Old Nov 9, 2012 | 10:02 AM
Manny2587's Avatar
If you have the wideband hooked up to ELD, how are you going to remove the ELD pin and use it else where...
And Miguel I realize that thread was about 00-05, however I posted in that thread that 06+ were different and that I found the correct ones to use. I should be getting about 10 06+ pins here in the next few days, ill let everyone know.
Old Nov 9, 2012 | 10:11 AM
liquidgsr's Avatar
I clipped the wire and ran the single for my wideband to it since the single from the ecu does nothing . The pin and part of the wire is still connected to the harness for the ELD but there is single coming through any longer since the wideband is sending a single to it now.
