ECU pin
I think you may be confused about how the wideband input works. The 0-5v output on your aftermarket wideband should be wired INTO the ecu using the Factory electronic load detector (ELD). Meaning you need to connect it to the ecu side of the harness.
The wideband is not receiving a signal, it is sending a signal to the ecu for purposes of data logging.
