EGT/Pyrometer Selection and Install
Old Feb 20, 2009 | 01:33 PM
dsddcd's Avatar
Default EGT/Pyrometer Selection and Install
So I just got my AEM EGT Sensor and I am disappointed. Their description online is the following.
The 30-2050 kits contains:
One RTD temperature sensor with male connector and male thread.
One mating connector assembly.
One weld-on bung w/female thread.
The real sensor is below, notice that the sensor has no male thread just a female coupling. I was planning on drilling and taping the manifold and screwing this thing in. Now that I have to weld, I have a mig welder but I am unsure of I should or if this if it can be welded and hold
Old Feb 20, 2009 | 01:36 PM
ya@inlinepro's Avatar
Most EGT sensors are like this. Not all manifolds will have meat in them to drill and tap the manifold.
This way is more universal where you'd weld the bung to the position and fit the EGT sensor it.
Old Feb 20, 2009 | 01:50 PM
dsddcd's Avatar
I ordered this particular EGT b/c I thought it was threaded, I asked Chris and he told me I was able to just tap the manifold. I am happy with the quality and sensor and will keep it but no I have to find a way to weld the bung onto the manifold.
Where do you recomend installing it, and what is your welding procedure?
Old Feb 20, 2009 | 01:55 PM
Downpipe will work fine
The aem egt works great, we have them for our race cars as well.
Welding procedures, if done properly, will also prevent leaks through a faulty tap.
But yea, on the downpipe will work
Old Feb 20, 2009 | 06:44 PM
dsddcd's Avatar
You want the EGT upstream form the turbo that is where the temperature reading is the most critical. Maybe if I was NA I could put it in the collector but the only thing I should be doing post turbo is the wideband.
Anyone have any sugestions on how to attach the bung?
Old Feb 20, 2009 | 07:31 PM
TRBOKEV's Avatar
Return it?
I just dont know if it would be a good idea in the cast mani...
Maybe a full race mani but not the ILP log mani.
Old Mar 3, 2009 | 01:30 PM
dsddcd's Avatar
So I have been looking into a pyrometer again and I can
Old Mar 3, 2009 | 06:54 PM
Sideways's Avatar
They weld in real nice.
Old Mar 5, 2009 | 07:16 AM
dsddcd's Avatar
Has anyone ever installed one in each runner of the Exhuast?
What about installing a perssure sensor in the manifold?
Old Mar 5, 2009 | 08:49 AM
siadam's Avatar
Originally Posted by TRBOKEV,Feb 20 2009, 08:31 PM
Return it?
+1 on returning it.
Unless you mount a pyro in each runner to monitor each cylinder individually...I don't see the point.
Wideband > single pyro.
