EGT sensor on AEM
Old Jan 13, 2010 | 10:38 PM
AusS2000's Avatar
Default EGT sensor on AEM
After my most recent turbo rebuild I decided it might be wise to check my Exhaust Gas Temperature.
I purchased an AEM 30-2050 Exhaust Gas Temp (EGT) Sensor Kit.
Installation was a bit difficult. There is no room for it on the turbo manifold before the turbo where it's meant to go. I had to install it just downstream of the turbo in the downpipe.
You can see it behind the turbo beanie.
I then went to wire it into the AEM EMS. The instructions that come with it say that polarity is not important and on the 30-1012 to connect it to +5V and one of the available EGT input channels. I chose A5 (EGT #1) and B7 (FM, +/-5V). And now that I read that I think I might see the problem. What does +/-5V mean? What does FM mean?
Where can I get 5V power on the AEM ECU? There are plenty of +5V Sensor connectors but they are all dedicated for various sensors.
Old Jan 13, 2010 | 11:32 PM
Spoolin's Avatar
I know this has nothing to do with your question but is the EGT probe a K type. If it is, it is polarity sensitive and if its hooked up backwards, the reading will be off.
Old Jan 14, 2010 | 09:49 AM
HiVolume's Avatar
What manifold are you using?
Old Jan 14, 2010 | 03:04 PM
AusS2000's Avatar
Hi, perhaps quoting the entire first message was a mistake when your question consisted of only one line?
It is the LoveFab Minime V1 manifold.
Old Jan 14, 2010 | 03:06 PM
AusS2000's Avatar
According to the documentation it is an RTD Style EGT Sensor.
Sensor Element: Platinum sensor in thin film technology.
Old Jan 14, 2010 | 05:38 PM
Spoolin's Avatar
I dont have any experience with those sensors so maybe they arent polarity sensitive. I'm more familiar with K type sensors. You'll probably be fine then and if they said it didnt matter about the polarity then I assume they know best.
Old Jan 14, 2010 | 06:50 PM
AusS2000's Avatar
Ok, I'll try one of the Sensor +5V.
Next question, Greddy Oil Pressure sender. I have one plugged in and it has three wires: Red, Black and White. I assume Black is ground and white is signal. Anyone know if Red is +12v or +5V? Any one have calibration figures for the Greddy oil pressure sender?
Old Jan 15, 2010 | 03:18 AM
AusS2000's Avatar
Sensor +5V worked! I can now read the EGT value in the AEM software.
The gauge is a little harder but I'm working on it.
Chance S2K
Mar 18, 2015 08:45 PM
TaylorBishopS2k
Jan 18, 2013 07:38 AM
Dr Jekyll
May 29, 2010 07:18 AM
SpyderS2K
Jun 11, 2007 09:13 AM
Hiz Dudeness
Jul 1, 2003 04:27 PM
