Elda Engineering Turbo Kit
Old Oct 25, 2004 | 09:34 PM
  #101
CrazyPhuD's Avatar
220ft/lbs at 4k? Wow!!! If you just maintain that till 9K you're talking about 375hp....wow.....even if TQ drops to around 200ft/lbs that still aroun 340hp. How much boost is the kit designed to run? Keep up the good work and can't wait for the final results.
As for people's issue with the E-manage I think many people are concerned how much the stock ECU will adapt to it. We're just concerned that the stock ECU will adapt to the tuning and cause a lean condition.
  #102
PMantis24's Avatar
Awsome! thanks for the great write-up and all the hard work you've done R&D'ing this kit, must be fun
Old Oct 26, 2004 | 09:18 AM
  #103
Wael El-Dasher's Avatar
While down at Fall Colors, I was able to get together with one of the premier vendors on this forum, they expressed a lot of interest in handling the kits promotion and sale/support. Everyone here loves this vendor so I am sure this will help get the turbo system into market sooner.
Thanks again for the support from the S2ki community.
cheers
W
Old Oct 26, 2004 | 09:35 AM
  #104
turbo_pwr's Avatar
Good Luck Wael, the kit looked great in person. Did the valve adjustment work out as well?
Old Oct 26, 2004 | 09:49 AM
  #105
iCEE's Avatar
...bookmarking
Old Oct 26, 2004 | 09:58 AM
  #106
Thanks Dan, the valve job was good. I thought all the hard miles on a dyno runs would have thrown the adjustment out sooner (car had 19k miles) but the tech was first impressed with how clean everything was, then when he checked the gaps, everything was within spec for the miles. Had it adjusted anyway to keep it tight.
Hope to see you again soon.
cheers
W
Old Oct 26, 2004 | 10:37 AM
  #107
CrazyPhuD's Avatar
Hmmmm...since this is now getting closer and closer to production. Has any work been done for MY04/05 and 2.2L. I assume you might need to tune the e-manage differently.
Old Oct 26, 2004 | 02:37 PM
  #108
hahnn002's Avatar
I was very close to purchasing another turbo kit, but changed my mind and really REALLY want this one. Thanks for all the work you've done on this kit. I'll just do other things to keep me busy until it comes out, like some 4.57 gears and some track driving classes!
Old Oct 26, 2004 | 02:54 PM
  #109
We have not done any 2.2l testing yet, however it would be safe to assume the car should run even better with the larger displacement. The maps should be pretty similar, however I am told the harness is a bit different.
cheers
W
Old Oct 27, 2004 | 06:50 AM
  #110
specialque's Avatar
If you need a 2.2L test this on, i'm your guy, and I'm just down the road from you in Fairfield CT
