emanage not communicating
Old May 18, 2007 | 07:53 PM
ChefJ's Avatar
Default emanage not communicating
I cannot seem to get my computer to communicate with the emanage. Me and my tuners were unable to get the computer to communicate with the emanage has anyone else had this issue and what may be causing it?? It is just giving a not communicating error on my computer and when they try it on theirs it just shuts down like there is some kind of software issue????? TIa
Old May 18, 2007 | 07:58 PM
Spec_Ops2087's Avatar
Are you using exact cable that came with the emanage and plugging it into the serial port (NOT using a serial to usb converter cable)?
The emanages are designed in a way that you cannot convert the serial port to a more usable USB port. Who knows why...
Old May 18, 2007 | 08:27 PM
revhi's Avatar
I use a converter from serial to usb and it works fine. Its more likely either a conflict of software or your just not using the right com port selection. Make sure the version of software that your running now is the same as the one your trying to open it with.
Uninstall and reinstall the program again and update it. http://www.mohdparts.com/emanage/
Old May 19, 2007 | 05:19 AM
CIVICTOS2000's Avatar
I had that problem using the laptop and the USB converter...I ended up taking the Desktop to the garage to use the serial , mine used to start updating and in the middle of the process it just failed... this almost drove me crazy.... also make sure the Regional settings of your PC are set up for US of A....
D.
Old May 19, 2007 | 07:16 AM
ChefJ's Avatar
I guess the software I purchase (from someone on here) was a rewrite and not the actual greddy disc. I payed for it like it was a greddy disk but it won't load on mainstreams computer. I now have to go to NOPI and buy a new cd 110$. !#%# $!$%! this turbo setup.
lagunabs2k
May 4, 2013 09:54 AM
jlovat12
Nov 1, 2010 11:52 AM
Shftat9k
Nov 8, 2007 11:39 AM
batikan
South Florida
May 1, 2006 05:28 AM
