EMS 1052 Non-UEGO
Old Jul 6, 2009 | 04:31 PM
Kirpich's Avatar
Default EMS 1052 Non-UEGO
They probably have a write-up on it somewhere, I couldn't find it. Sorry
Simple question:
Which pin on EMS D connector does the wideband (0-5V) output from Innovate wideband controller goes to?
Or on the stock harness? Connector A, B, or C?
I have a simulated narrowband 0-1V going to pin C16, primary O2 sensor pin.
And which settings I turn on in AEMPro software?
Thank you.
Old Jul 6, 2009 | 08:47 PM
Kirpich's Avatar
No way nobody knows! I refuse to believe in ignorance!
Old Dec 30, 2009 | 06:58 PM
Kirpich's Avatar
Bump. Help!
Old Dec 30, 2009 | 07:11 PM
AusS2000's Avatar
Not sure which pin to connect it to on the 1052. I suspect it C16 instead of the 1V O2 sensor.
As for calibration, just run the O2 Sensor Wizard. I'm assuming the Innovate will be there.
Old Dec 30, 2009 | 07:18 PM
chris_barry's Avatar
I used a WB02 techtedge unit which has a differential output.
Connect C18 to the sig gnd, and C16 to the sensor output on your wideband.
Set your units first using ( for some reason you have to do this, even if they are already appear correct).
Configure > units > and select AFR fuel or Lambda
I then went to
setup> sensor > oxygen sensor >o2 #1 > O2 cal table
and input your values for ARF vs voltage. It its linear just change the top/bottom value, highlight the lot then select calculate.
If you select Lambda units you will need to change your automap settings to reflect the approx 1/14 change in the numerical values of the units.
Old Dec 31, 2009 | 12:12 PM
Kirpich's Avatar
Chris, the C16 (primary O2 input) will need the wideband output from innovate? I have that being used by the gauge. I wonder if I can T off of it...
Old Dec 31, 2009 | 01:42 PM
Yes, should be OK, especially if its a differential output ( a push/pull affair with a floating ground).
just make sure you also put a T in the signal ground from the innovate as well and connect to C18.
BTW, I fired up the software and there is already a wizard for the innovate.
Old Jan 6, 2010 | 06:42 PM
Kirpich's Avatar
Thank you sir.
Jaspah
Nov 5, 2015 01:13 PM
rikhemi
Aug 12, 2014 07:26 AM
marcpb443
May 3, 2010 08:30 AM
Nobody
Apr 22, 2005 01:54 PM
Diddy
Aug 14, 2002 10:07 AM
