EMS and 750 injectors addition
Old Sep 22, 2006 | 07:26 PM
news2kroller's Avatar
Default EMS and 750 injectors addition
I am going from the stock comptech s/c kit and adding the AEM ems with UEGO as well as rc 750 injectors, my 4.25" pulley is a few weeks away but i was wondering if it would be a big problem to plug and play the ECU, install the Injectors myself and change the Comptech FPR back to the stock one (im thinking this might be a problem) and then drive the car to get a tune? after i got the pulley i would get a re-tune which would hopefully be easy and quick. any ideas would help. thanks
CHRIS.
Old Sep 22, 2006 | 10:40 PM
Kwando's Avatar
injectors are easy... make sure you know where the spacers go...
ems is just plug and play... load the basemap and see if it starts... i would limp it to your tuner or best thing to do is to tow it...
Old Sep 25, 2006 | 12:03 PM
timg's Avatar
Should be easy. PM me, I probably have a base map that you can start with.
Tim
Old Sep 25, 2006 | 02:04 PM
Dsgs2k3's Avatar
no, 750cc is a bit too big for that kind of boost. it will work but it will just dump fuel into your car causin it to probably stall out if you dont have the correct settings. and dont ever drive it. get it towed
Old Sep 25, 2006 | 05:08 PM
timg's Avatar
With the stock ECU, this is 100% correct. With the AEM base map, this is 100% correct. Remember, these injectors are over 2x the size of the stock ones. Anything that was designed for the stock 360's won't work.
If you have replaced the AEM base map with one that has been adjusted for the injectors and for boost, you should be able to drive to the tuner. It may not be perfect, but it should run and drive.
With a freshly built motor, I would probably NOT run an unknown/untested base map until after the motor was broken in.
Tim
Old Sep 26, 2006 | 11:26 AM
im going to order the belt today and i was looking at sideways thread ( https://www.s2ki.com/forums/index.php?showtopic=254159 ) and it seems i need a 4060395 gatorback belt for my incoming 4.25" belt. Is that still the right belt to get? thanks
CHRIS.
Old Sep 26, 2006 | 11:10 PM
C4SxM5's Avatar
PM'd OP
rikhemi
Mar 13, 2014 01:02 AM
Headchef
Mar 1, 2007 05:46 PM
QUICK_AG
May 19, 2006 12:05 AM
r_duff
Oct 28, 2005 09:41 AM
bumpins2k
Aug 20, 2005 04:30 PM
