Engine bay heat
Old Aug 18, 2006 | 07:37 AM
  #31
XclusiveAutosports's Avatar
^ I would also like to know.
Old Aug 18, 2006 | 07:47 AM
  #32
CaptKirk's Avatar
Originally Posted by OGPackin,Aug 18 2006, 11:12 AM
Nope AC.....When you turn the AC on the 2nd fan kicks on
Oh wow, def. good to know....
I always thought it was better to turn on the heat to full to cool down motor...
Old Aug 18, 2006 | 08:00 AM
  #33
KRAZYKOREAN's Avatar
Gold Member
Well the car still runs alittle hotter with the ac but not much since the 2nd fan is there. But turning the heater on does help alot to lower the temp. But of course it sucks in the car cuz its hott
Old Aug 18, 2006 | 01:20 PM
  #34
CaptKirk's Avatar
Oh I know... it def sucked the few times I had to use it
Old Aug 18, 2006 | 02:04 PM
  #35
ex-eclipse's Avatar
You guys have thousands of dollars in turbo set ups and no Koyo radiator? As soon as you get one you wont need to drive around with the heater on when its already 90* outside.
Old Aug 18, 2006 | 02:09 PM
  #36
OGPackin's Avatar
Ahhheem...
Old Aug 18, 2006 | 02:42 PM
  #37
CaptKirk's Avatar
Upgrading the cooling system is on the list of things to do
Old Aug 18, 2006 | 02:54 PM
  #38
herecomesboost's Avatar
You can either turn on the A/C or turn on the heat to reduce the water temp. As stated already, turning on the A/C turns on the second rad. fan. If you turn your heat on full blast, you are cooling down the water because you are blowing air over the heater core (a small radiator). Obviously, the AC way is easier on the driver
Kyle Ritchie
Old Aug 18, 2006 | 04:15 PM
  #39
fperra's Avatar
Originally Posted by OGPackin,Aug 18 2006, 03:09 PM
Ahhheem...
OG, your engine bay looks better than mine and that says a lot. I can't let this be, so I'll have to work on it.
Old Aug 19, 2006 | 02:17 AM
  #40
OGPackin's Avatar
Thxs meng!
