engine damper on turbo S2000
Hello,
I have a NRG engine damper with the S2X puddymode bracket which i bought when i was N/A but never got arround to fitted. Now i am thinking to install it cause the engine under turboing moves quite a lot. I have a PFAB ELMT kit. Has anyone fitted an engine torque damper with this setup?
Thank you for your reply. Yes it cannot fit with my intake pipe. So i am looking for another solution if anyone has done it. Most possibly if anyone has customize brackets and fit the engine damper in another position
http://vimeo.com/28739310
Damper not dumper....
Don't the inovative mounts have a high failure rate though. Im looking for a etd mount for my pfab setup as well. Has anyone tried mounting one on the other side? Maybe to the intake or alternator bracket.
Well i was passenger in an S2000 with innovative 75A and it was like being in a tractor
I do not know how the 65A would be but i will take your experience for it. I think the torque damper if someone can fit it is a better solution and does not cause any vibration, so i would look for that solution first
