engine damper on turbo S2000
Old Sep 18, 2011 | 12:35 PM
Corey Maurer's Avatar
there are alot of failures in the innovative mounts, but what is rarely or never taken into consideration is these are usually on bottom mount setups.. and usually without the heat shield that innovative sells to correct that failure
Old Sep 18, 2011 | 01:02 PM
03supers2k's Avatar
If you engine is moving a lot your motor mounts are going bad. Get some innovative motor mounts and you wont have to worry about a engine dampner.
Old Sep 19, 2011 | 03:56 AM
HMFIC's Avatar
On the Ptuning turbo kit, the passenger side mount is replaced with a solid mount. Other mounts are stock.
I had to replace my driver side engine mount because I was really getting a lot of movement and I suspected the driverside engine mount was failing. Sure enough, when i went to replace it with another stock one, it was split in two.
I don't drive my car much so for me to use the stock was fine. If that fails again one day, i'll upgrade that along with the tranny mounts to the megan poly mounts or whatever is out there.
I would replace with poly mounts but if you're that worried about vibration, maybe stock is better for you.
Alexander Startsev
Aug 20, 2016 12:21 PM
YuriArts
Dec 29, 2011 06:32 PM
rikhemi
Dec 1, 2010 07:47 PM
Tech7427
Nov 6, 2010 05:34 PM
Spoolin
Oct 26, 2006 10:34 AM
