engine fire...
Old May 31, 2009 | 08:16 AM
AndyFloyd's Avatar
Originally Posted by GDM S2K,May 31 2009, 06:34 AM
another thing to add to regular checks on a turbo car.
Check all fittings and lines for anything thats not normal
i was unde the hood the night before checking everything before i went to the 1/4 track, too bad i only made it like 10 miles. lol Oh well, i checked everything but the oil feed line the night before. Guess next time I wont let this happen cause ill be checking its tension every day now. haha
Old May 31, 2009 | 08:24 AM
GDM S2K's Avatar
damn I dunno what to say just bad luck at the time good to hear it wasn't to bad
Old May 31, 2009 | 10:20 AM
SgtB's Avatar
I had an idea about that bolt last night. Bare with me it's weird.
Take a cheap box end wrench, the size of the fitting, and cut it in half. Bend it right at the box to a 90deg angle. Slip it over the hose , handle facing down, and slide it out of the way while you tighten the fitting down. Once it's tight you just slide the wrench onto the fitting and it tucks between the turbine and the compressor locking the nut in place. Ghetto, but cheap and effective I think.
I ran my kit for weeks, and it blew the feed on the dyno of all places. Murphey at work.
Old May 31, 2009 | 10:51 AM
AndyFloyd's Avatar
haha thats interesting sgtb....haha. I can see how it would work since it wont allow the nut to spin back the other way. I dunno with a topmount that might look kinda silly. lol
Old May 31, 2009 | 11:04 AM
phils2k's Avatar
Originally Posted by AndyFloyd,May 31 2009, 04:14 PM
yep mine are aluminum GT restrictors bought from ATP turbo. This oil fitting is now stripping out again since its aluminum and the threads get effed so easily. Where did you find the fittings you now use? Thanks!
yes mine were the exact same, the threads stripped
i had to go to a garrett turbo specialist here in the uk, to get them to make me the correct size restrictor out of steel but that was no hassles and the steel couplings i got from a normal hose and fittings store. they are still made by earl fittings
Old May 31, 2009 | 11:07 AM
AndyFloyd's Avatar
thanks phil, im gonna make some calls tomorrow and get some stainless steel fittings so i can solve this issue. You rock man!
Old May 31, 2009 | 11:19 AM
phils2k's Avatar
no worries, sorry i cant help you more but i am sure you will be able to get them from over in the states, hell mine probably came from there in the first place from the shop lol
since i did this though, no problems with the oil feed, not even moved after 3000 miles
Old May 31, 2009 | 11:38 AM
phils2k's Avatar
http://store.summitracing.com/partdetail.a...15&autoview=sku
https://www.slowboyracing.com/product.php?p...34&bestseller=Y
these are similar to what i used
Old May 31, 2009 | 12:21 PM
AndyFloyd's Avatar
phil you are a great asset to this site, thank you. Hows 600whp treating you? you gotta be loving it, must feel like a giant got behind your car and just shoved you forward in every gear...so much power on tap.
Old May 31, 2009 | 12:32 PM
JoeyBalls's Avatar
I say have a Fire extinguisher in the cabin (underneath pax feet) and have it routed by a hose of some sort to the "problem areas" just in case something goes wrong and you see fire, you can "blow the bottle", usually when you have a fire under the hood and you open it, that influx of fresh Oxygen makes a big problem huge.
