Engine Oil Pressure
Old Oct 7, 2005 | 11:54 AM
Danyellow02's Avatar
Default Engine Oil Pressure
Hello all,
I am boosting my "toy" with a turbocharger. Recently, I have found a problem that the engine oil pressure drop when the engine get hotter.
When the engine is running at the idle the oil pressure indicates at the Honda's Spec. ( 2.5 kg/cm^2... something like that)
After couple boostings as I mentioned then let the engine run at idle. The pressure indicates at the range 1.5 to 2.0 kg/cm^2 instead of 2.5.
I'd very much appreciate for any appropriate advices
Thanks
Dan
Note: I am using the Greddy oil pressure gauge and running with 10-30 Mobil one full synthetic
Old Oct 7, 2005 | 12:33 PM
msm_s2k's Avatar
Heat ---> lower oil viscosity --> lower oil pressure.
Do you have an oil temp gauge?
Old Oct 11, 2005 | 09:34 AM
Thanks for your respond,
I agree with you that the vicosity of the oil get thinner when it is hot. My concern that I have lost approximate about 10 psi.
I don't have the oil temperature gauge. However, when I installed the oil pressure gauge. I left the wire which used to be for the factory oil pressure out ( unconnected)
Do you think that would cause the engine not to read the oil pressure?
Thanks
Dan
cheddaboy
Dec 6, 2015 02:41 AM
08s2000CRbackinblack
Jul 9, 2011 09:41 AM
Spoolin
May 16, 2010 08:43 AM
SPLNDID
Oct 14, 2008 07:56 AM
Arbeeezy
Oct 17, 2005 12:49 PM
