Engine Rebuild
Old Feb 1, 2005 | 06:39 AM
kstokell's Avatar
Default Engine Rebuild
Hi Guys,
I have a spare short block assembly with a damaged cylinder 4. The block consists of the crank, rods, pistons, oil pan and pump etc.
I'm thinking of re-building this block for use with a Vortech SC running at higher than stock boost. I'm currently running the Vortech at stock boost on a new short block.
Any suggestions on what the best way of doing this would be gratefully appreciated?
Please remember that I live in The Netherlands (Europe) so shipping big lumps of metal backwards and forwards to the USA would be expensive!!
Thanks
Kevin
Old Feb 1, 2005 | 03:51 PM
fperra's Avatar
Well, for sure you need to get it sleeved. Is there anywhere on your side of the pond that does that? You can use the stock rods, but I would get them cryo treated. You should also add some forged pistons - with a SC, 9.5:1 or even 10:1 should work fine. My 2 cents.
Old Feb 1, 2005 | 04:03 PM
Slows2k's Avatar
I'd sleeve the block, it will be the only way to save the block. It will be expensive unless you can find someone in Europe to do the job. 9 or 10:1 would be fine, with a 12 psi pulley. At 12 psi you won't have to worry about belt slippage.
What are you running for engine management now?
Old Feb 1, 2005 | 11:14 PM
kstokell's Avatar
Currently I'm running the standard engine managment with the Vortech supplied piggy back system. I'm assuming on the new block that I will have to go with a new system including larger injectors.
How much does sleeving cost in the USA, including a set of new low compression forged pistons?
Do I require and cylinder head work, or can I take it of the standard block and bolt it directly on the sleeved one?
Old Feb 2, 2005 | 06:44 AM
S2000_Europe's Avatar
Kevin you have two ways:
I bought a Short block in US to build it, since the euro rate is favorable to us shipping cost are not very high.
I know some one in UK who maybe can build you the block.
Old Feb 2, 2005 | 10:46 PM
kstokell's Avatar
S2000
Who is your contact in the UK?
Are you still selling that WB O2 sensor you had?
Kevin
drhess06259
Sep 21, 2009 06:13 AM
kinetica
Mar 10, 2006 07:16 PM
