Engine rebuild advice pls
Originally Posted by camuman,Sep 3 2009, 10:01 AM
laskey bottom end stock bore, 10:1CR or less.,F22crank. i personally would go 9ish:1. your boosted and bear that in mind. boost is drug.......you give up approx 10whp per full compression point drop, but can crank boost up to more then compensate
/thread
/thread
If I do it over I will go 12:1 at 14psi all day..... with built bottom... (thats the supercharger set up)
Turbo I am going 10:1...... too chicken too go lower... my NA days are embedded in my brain still
Originally Posted by LeonGalt,Sep 3 2009, 03:17 PM
Interestingly, even though my current pulley was sized to give around 11psi (3.4") I was hitting 13 psi with some belt slip at the top.
If your absolutely positive your not gonna go over 15psi (dude no one stays at a certain psi your gonna want more) then just throw in 10:1 or 10.5:1.
But like everyone else is telling you its really not noticeable at 9 or even 8 when you got the boost and its leaves SOO much room for power... So even if its really the last build you do you can always turn up the boost!!!
Originally Posted by juntuned,Sep 3 2009, 03:45 PM
hhmm... do you still have belt slip... maybe try cleaning all the pulleys and using a slightly tighter belt size...... FYI... not tooo tight or the water pump pulley might break. (better chance of getting struck by lightning.... but hey... happened to me.)
At the time of the belt slipping we were placing the blame on the belt not being the best kind. The tuner gave me some other belt recommendations so I'll see how those do. I also haven't tried the spray on sticky method either.
Also, I'm very sure I won't be going further than this blower. I think it peaks at 15psi or so and even that is probably more than I want to see in this car. I have been turbo'd before and know all about the addiction. But I've spent stupid money on this car and its only getting worse, so a line has to be drawn somewhere. Really, if it's not enough, I'll by a vette.
I was actually hoping to be done with the car after the tuning session, had no plans on a motor rebuild at all. But since it's here and I have to deal with it, might as well build it better than stock.
Thanks,
J
Originally Posted by LeonGalt,Sep 4 2009, 06:39 AM
Hmm, now we're talkin. 12:1 at 14psi sounds very appealing to me. Have you seen this build done before?
Originally Posted by juntuned,Sep 4 2009, 02:59 PM
well yeah lower the compression for crazy psi... 15+ which is why everyone with crazy power does lower compression. (15psi+ = crazy power).
If you take a 14 psi set up and lower the compression you will obviously make less power. power and reliability are never really paralleled unfortunately.
its just what you do when you build a FI car for reliability. now, race cars, yeah, they run higher CR, but they also rebuild there motors way more often
Originally Posted by camuman,Sep 4 2009, 01:00 PM
i am sorry dude. i misread it, rough day at work.
