Engine rebuild advice pls
Old Sep 4, 2009 | 04:45 PM
  #21
S2oooNvegas's Avatar
Compression has to match the cam profile.
All those boosted cars referenced here mean nothing. They have cams specific to boost. This car has huge cams, and remember that drops the dynamic compression considerably, leaving no reason to drop compression at all.
hence all the s2ks hitting over 700 on unopened motor.
Leon your bottom end is likely perfect. Pull the head and inspect for scoring in the bore. if none, verify that it is the valve guides that have gone bad, which trashed the valve seats. Which is what will cause your high leakdown on several cylinders.
i say toss on the proflow head, use stock head gasket and bolts, add good management and boost up a storm.
Old Sep 4, 2009 | 06:25 PM
  #22
spectacle's Avatar
For your power goals lowered compression is not a necessity. I'd leave the bottom end alone as well. Don't fix what isn't broken.
Old Sep 5, 2009 | 05:43 AM
  #23
OKSTWOK's Avatar
Spectacle, I always enjoy your input in the FI forum but he has mentioned he is having issues with his compression readings on teh 100k+ block he is running.
Leongalt, please solve the mystery as we have seen no numbers on your cylinder compression and HP numbers provided to you by your tuner. This information would be most useful to make a determination of block issues versus tune issues. On that note, have you contacted Chris @ SOS to get his thoughts on the proper CR for your kit?
B
Old Sep 6, 2009 | 05:04 AM
  #24
killabee's Avatar
B
We need more Info. As far Is this board goes there Is a ton of good info but when It comes down to It call a professional.
Old Sep 6, 2009 | 02:25 PM
  #25
LeonGalt's Avatar
This would be fantastic for me actually, best solution I could hope for. And yes, i agree, more infor would be helpful and now I am home and have access to the numbers, so here ya go:
Compression
1: 230
2: 230
3: 225
4: 232
Leak Down
1: 4%
2: 9%
3: 12%
4: 5%
Mods on car
Stock AP1 motor, Kpro, J's header, test pipe, 60RS exhaust, SoS throttle body, 3.4" pulley, Injector Dynamics 725cc.
Made 360 whp, 214 torque, perfectly flat 12.2 AFR. Boost was varying between 11psi and 13psi.
The car also eats about 1 quart of oil every 1000 miles. Any time I get on the throttle at all, huge clouds of black smoke out the tail.
It is very tempting to put the head on and go with it as is. If the bottom end is fine, I am not interested in touching it.
Thanks,
J
Old Sep 6, 2009 | 03:16 PM
  #26
stena's Avatar
by my standards your motor is fine,,
Just if you feel like it put the new head on and drive some more..
and will hit 370 probably..
stefce
MARK AUS S2K
Mar 16, 2016 07:11 PM
ZSAK
Jul 28, 2015 07:04 AM
boostedf22c
Mar 27, 2015 09:25 AM
NFRTurboTerror
May 23, 2007 07:44 PM
