is it enough?
Old Sep 13, 2007 | 07:12 PM
driftintherain's Avatar
Default is it enough?
im thinking about boosting my car. is this kit a complete kit?
InlinePRO S2000 Turbo Kit
InlinePRO's full production turbo kit for Honda S2000.
-InlinePRO Cast Iron T3/T4 Turbo Exhaust Manifold
-Precision Turbo GT 35/55B or GT35/61E Turbocharger
-Turbosmart 38mm Wastegate
-InlinePRO Billet Blow-Off Valve
-2.5" Mandrel-Bent Aluminum Charge Pipes (mirror polished)
-InlinePRO 600hp Front Mount Intercooler
-High Temp Charge Pipe Couplers & Reducers
-3
Old Sep 13, 2007 | 07:22 PM
2big4aS2000's Avatar
new map sensor
boost controler
uego
cat back single exhaust
injectors
does it come with oil filter relocator?
oil cooler recomended
water & oil lines to turbo
fitting in oil pan for return (needs to welded!)
depends on how much you want out of it but a 3mil head gasket is highly recomended
** have 2 of these on cars in the shop (2nrwerks.com) right now - really makes your s2000 a scream to drive!
Old Sep 13, 2007 | 09:27 PM
Sideways's Avatar
Which High Pressure 600hp In-Tank Fuel Pump are you going to use?
Old Sep 14, 2007 | 05:43 AM
i thought the fuel pump was included in the kit..
Old Sep 14, 2007 | 08:19 AM
ya@inlinepro's Avatar
it is
Old Sep 14, 2007 | 09:01 AM
what kind of management system do you recommend?
Old Sep 14, 2007 | 10:02 AM
Spec_Ops2087's Avatar
AEM EMS ftw
It'll make the car feel like stock only with 100+ more horsepower
Old Sep 18, 2007 | 02:25 PM
scareyourpassenger's Avatar
I prefer the emanage ultimate. My car feels better than stock and it will pass emissions.
On my ap1 with comptech sc runnning 8psi I pulled 360whp with 220ft/lbs. Tuned by Holy Roller Dyno!
Old Sep 18, 2007 | 04:45 PM
JDMKID35's Avatar
Banned
AEM is the way to go if you can have the $$$$$ we have had lots problems with the unit
Old Sep 18, 2007 | 05:00 PM
What kind of issues have you seen? I have had nothing but a positive experience with it.
