is it enough?
Old Sep 19, 2007 | 01:35 PM
afwfjustin's Avatar
Originally Posted by scareyourpassenger,Sep 18 2007, 05:25 PM
I prefer the emanage ultimate. My car feels better than stock and it will pass emissions.
On my ap1 with comptech sc runnning 8psi I pulled 360whp with 220ft/lbs. Tuned by Holy Roller Dyno!
wow good numbers, what type of dyno was this on?
Old Sep 19, 2007 | 02:08 PM
scareyourpassenger's Avatar
It was on a dynapack. Before you or anyone else comes to the conclusion that they read high please read this article. dyno compare
I wouldn't have my car tuned on any other type of dyno.
J
Old Sep 19, 2007 | 05:37 PM
thatsahonda's Avatar
Originally Posted by JDMKID35,Sep 18 2007, 04:45 PM
AEM is the way to go if you can have the $$$$$ we have had lots problems with the unit
you probably don't know how to use it correctly
Old Sep 19, 2007 | 06:33 PM
ChefJ's Avatar
Originally Posted by 2big4aS2000,Sep 13 2007, 07:22 PM
new map sensor
boost controler
uego
cat back single exhaust
injectors
does it come with oil filter relocator?
oil cooler recomended
water & oil lines to turbo
fitting in oil pan for return (needs to welded!)
depends on how much you want out of it but a 3mil head gasket is highly recomended
** have 2 of these on cars in the shop (2nrwerks.com) right now - really makes your s2000 a scream to drive!
Fitting in the oil pan for the return doesn't need to be welded. Just use the drain plug hole for the return, they make a fitting.
Old Sep 20, 2007 | 07:07 AM
geists2k's Avatar
No, don't do that. Oil will back up into the turbo and cause the seals to go bad.
Ask me how I know.
The current InlinePRO kit comes with a fitting that you should tap high into the pan or into the girdle of the block.
Old Sep 20, 2007 | 08:12 AM
2big4aS2000's Avatar
[QUOTE=ChefJ,Sep 19 2007, 06:33 PM]Fitting in the oil pan for the return doesn't need to be welded.
buzz944
Feb 25, 2010 03:55 AM
quinns2k
15
Jan 3, 2010 11:18 AM
Jc S2K2
Cars for Sale
18
Jan 6, 2009 05:28 AM
