evo injectors in a s2000?
Old Mar 19, 2010 | 11:52 AM
riceball777's Avatar
Default evo injectors in a s2000?
will stock 2003 evo injectors work on a s2000?
i know they are 560cc
Old Mar 19, 2010 | 02:04 PM
Kyushin's Avatar
Banned
You will definitely need engine management and a tune, but fitment? I cant really answer but I do know stuff like that will need adjusting.
Old Mar 19, 2010 | 02:37 PM
DeadZero's Avatar
any injectors other then STOCK, will need an engine management
Old Mar 20, 2010 | 11:49 AM
I know u need to tune them
But I'm asking if they fit in my 2002 s2000.
Do they plug in like stock? Can I just install them a d get tuned ?
Old Mar 22, 2010 | 02:06 PM
bump for answers
Old Mar 23, 2010 | 01:15 PM
Tech7427's Avatar
none of us will know unless you compare the stock s2k injector with the evo injector sizing..length, inlet diameter , o ring placement, injector clips design etc
Old Mar 23, 2010 | 02:15 PM
goldsS2000's Avatar
They should fit as long as you have OBD1 honda clips, new injector seals for the fuel rail, add washers on the studs for the fuel rail as the DSM injectors are a tad longer, and a resistor box will be needed as well
edit
you will need to take a razor or something sharp and file down a little tab thats on the inside of the injector so theyll snap into the OBD1 clips. After that theyre practically pnp
jdmrick
Oct 10, 2013 07:50 PM
jdmrick
Oct 9, 2013 08:37 PM
Clayman
Nov 2, 2008 02:54 PM
BLOWNJROCK
Jul 27, 2005 10:26 PM
