exhaust for fi
Old Aug 17, 2007 | 12:36 PM
hokies2000's Avatar
oops my fault I guess I did misspeak I'd trust slimjim. If anyone knows about flow he does.
Old Aug 17, 2007 | 01:21 PM
phils2k's Avatar
slimjim i am going to be using the gt35r and a laskey block and head, so are u saying the hks hi power dual would be fine or the ultimate racing dual
cheers bud
Old Aug 17, 2007 | 03:52 PM
slimjim8201's Avatar
cheers bud
You will hit it with enough boost and the UR dual. The HKS is highly restrictive, but much, much quieter. 450 is just about the max you are going to be able to get out of the HKS unless you crank the boost way up. But to remain on pump gas I'd recommend against it. The inline kit w/ 3mm hg, GT35R, 18psi, and HKS will yield about 420-430 rwhp. 20-21 psi should do the trick.
It all depends on what you want.
Old Aug 17, 2007 | 04:00 PM
KeithM's Avatar
T1R 70R sparrow. No drone, looks great
Old Aug 17, 2007 | 04:14 PM
Spec_Ops2087's Avatar
I'd doubt even 420-430hp with 18psi. I had an invidia (less restrictive then HKS), 18psi GT3R InlinePRO turbo kit and only made 415rwhp, your probably looking at 400rwhp on the dot.
But as you said, its going to take 21+psi to get to the 450rwhp mark with a dual setup.
Old Aug 17, 2007 | 05:02 PM
The blue line is an InlinePro GT35R setup with an HKS exhaust @ 18 psi. He made something like 460-470 with the 3" single.
Old Aug 17, 2007 | 05:08 PM
Well if thats the same exact setup, then were diving into the relm of different dynos, different conditions, different engines, etc since (assuming) the setup is the same as mine.
Old Aug 17, 2007 | 05:22 PM
leo520's Avatar
Originally Posted by nearwater4me,Aug 17 2007, 01:01 AM
What if I use a HKS hi-power for a turbo kit? say, Greddy?
I'm looking for around 280-300WHP.
would it be a bad idea?
I'm not too worried about losing some HP, just asking if it's gonna hurt reliability(if any)?
Thanks guys
Dan
is ur s2000 are 2007 models??
how can u go turbo?
Old Aug 17, 2007 | 06:04 PM
how can u go turbo?
Get a piggyback/Kpro/ or modified AEM EMS and change out the fuel system...your golden from there on
Old Aug 17, 2007 | 06:10 PM
leo520's Avatar
too bad .. all ur DBW functions gone, CEL light on all the time, that sux u know.
and also Kpro doesn't work with the 06 + DBW s2000's.
