exhaust for supercharger
Old Feb 12, 2007 | 11:20 AM
coastieap2's Avatar
Default exhaust for supercharger
okay, Im a noobie here and I know this has been asked a bunch of times, but I dont get a lot of chances to get online so Im just going to ask this and hope for responds. So I will be getting the vortech supercharger and I need to know what exhaust will give me the most power. I was reading and thinking of the J's header and custom 3 inch single exhaust. If I do that what test pipe will work and I do know that when it goes to 3 inches, it needs to be a gradual increase. So let me know if this setup will be the best. Thanks
Old Feb 12, 2007 | 06:56 PM
gomarlins3's Avatar
That sounds good, but if you change your exhaust, be sure to check you AF ratio after. Mine was running lean with the aftermarket header/ TP/ exhaust.
Old Feb 12, 2007 | 07:15 PM
Erick S's Avatar
T1R 70 mm
Old Feb 12, 2007 | 07:49 PM
pushin9's Avatar
if you get a custom 3" single made why use a test pipe? Just have it built right off your header.
Old Feb 12, 2007 | 08:23 PM
CourageOO7's Avatar
No man, the cool thing to do is to just run it out the header. No real FI guys use mufflers...those eat up power.
Old Feb 12, 2007 | 09:37 PM
batikan's Avatar
Originally Posted by Erick S,Feb 12 2007, 11:15 PM
T1R 70 mm
Hell Yea!!!
Old Feb 13, 2007 | 08:44 AM
coastieap2's Avatar
If I run the custom 3 inch from the header back, what will do with the sensor that goes in the cat?
Old Feb 13, 2007 | 08:52 AM
pushin9's Avatar
you just have a bung welded in very easy.
s2jay again
May 10, 2012 06:24 AM
Oscypek
Mar 8, 2009 01:52 PM
qbmurderer13
Jan 24, 2008 05:24 PM
dmw16
Feb 11, 2007 10:26 AM
jeffkenn
Aug 2, 2004 01:21 PM
