F/I and Traction Control
Old Dec 28, 2013 | 12:40 AM
Nyther's Avatar
Default F/I and Traction Control
First off, i did a search bur couldnt find some good results
Im running a ap1 with a mild but very quick spooling turbo setup:
https://www.s2ki.com/s2000/topic/102...h-turbo-build/
370whp gtx3071r
I do have serious traction issues in 2nd gear and occasionally in 3th gear. My rear end wants to do a 180 alot.
Im planning on upping the boost towards 400/450whp but the traction issue is getting on my nerves.
I still gonna do boost by gear but on somewhat colder days i would like to have some more "protection" from a TC.
I hear good things about the Racelogic but its really expensive.
I noticed the aem always had a TC feature, but was not so good as the racelogic. Im wondering if the TC feature in the series 2 has been updated and im curious if someone has this working properly on his ap1. Since i already own the series 2, this would be a great cost saver over the racelogic.
Who can chime in?
Old Dec 28, 2013 | 12:46 AM
pettyboy69's Avatar
What tires do you have? You shouldn't be having that big of traction issues at that power level with a decent tire under the car
Old Dec 28, 2013 | 01:13 AM
benes2k's Avatar
K pro works the best for our cars.
race logic makes a stand alone system that works well too but I heard it was $1000.
Old Dec 28, 2013 | 01:27 AM
Nyther's Avatar
Im running 245 direzza star specs in the rear. No issues on a warm dry, sunny days but here in the netherlands the temps are overall quite low so i need to be carefull hitting the throttle on colder days, but i still would like to use the aem's series 2 TC feature to have some more safety. Especially in the wet.
Old Dec 28, 2013 | 04:27 AM
s2000442's Avatar
Sounds like you need a better all season tire, and stay away from extreme summer only tires. I would limit the boost in 1st and 2nd gear to max of 8-10psi and then full boost in the upper gears like you mentioned.
Old Dec 28, 2013 | 05:12 AM
Phill24's Avatar
What size rims do u have?..i would suggest upgrading to a 265 all season tire of u can get 275 or 285 that would be even better
Old Dec 28, 2013 | 05:33 AM
RAIN H8R's Avatar
A cooder weather tire may help.
What ecu are you running? I have kpro with the hondata traction control system. It works VERY well. Id be happy to share the calibration file if you go this route.
Sent from my Samsung Galaxy S4
Old Dec 28, 2013 | 05:53 AM
Nyther's Avatar
Like mentioned, i got the aem series 2 and it will be way too much costs to switch to a new ecu and a new tune, so the question is, how does the TC feature of the series 2 perform and has anyone here succesfully used it?
I could switch to some other tires but im sure the engine power will always win in wet/moisty conditions so a TC will be more safe to have. thanks for the replys so far guys!
Old Dec 28, 2013 | 06:56 AM
Funtimefrankie's Avatar
Not wanting to jack the tread but I'm also in for any info on this..
I am currently making the leap from a Garett TR30R MASE set up to a GTX3576R Sheepey mani 320whp > 550whp (estimated).
I'm also on a AP1 with a series 2 AEM EMS.
I have AD048R 255s at the rear which is pretty much the best tire I can run but fear that similar weather conditions in the UK to Netherlands I will soon be looking for some kind of TC also..
How does the EMS TC feature work?
Also @ OP, where about's in Netherlands are you? I happen to be over visiting Den Haag at the moment. Nice city but not many roads to unleash a boosted S :-)
Old Dec 28, 2013 | 09:44 AM
RAIN H8R's Avatar
I would consider a call to the aem technical phone line. They are extremely helpful and will most likely answer your questions better than us forum guys.
