F20 and F22 parts interchangeable?
Originally Posted by Silver S2k4,Jan 16 2008, 02:10 PM
Confirmed by Inline pro, all that is different is the crank.
Originally Posted by J'sBlackAP1,Jan 16 2008, 05:22 PM
So if there ARE benefits to fitting an F22 head on an F20 block.. what are they?
Originally Posted by PeanutButter,Jan 16 2008, 05:23 PM
WRONG, BUT if you want to think that go ahead and try to put the ap1 pistons and rods on an ap2 crank
The F22C's bores are the same dimension as the F20C. The displacement change is due to the longer stroke crank. Rod length and piston height are different between the 2 engines. Displacement is changed by 2 dimensions, bore and stroke. Rod length does not change displacement.
If you take the rods, pistons and crank from a F22C and put it in a F20C block it's now a 2.2L
If you take a F20C rods, pistons and crank and put them in a F22C block it's now a 2.0L Irregardless of what is stamped on the outside.
Originally Posted by Slows2k,Jan 17 2008, 12:01 PM
It would be an F22. A safe redline would be the same as a factory built F22.
