f20c f22c piston the same?
Old Aug 15, 2008 | 12:53 AM
jzz30's Avatar
Default f20c f22c piston the same?
i just recieved a set of cp pistons for my f22c build and the part number is the same as f20c but i ordered for f22c. are the pistons the same? it doesnt make sence...
F20C 87mm Bore x 84mm Stroke - 8.815" Block Height (from BC's website)
F22C 87mm Bore x 90.7mm Stroke - 8.815" Block Height
the difference in stroke is f22c is +6.7mm
Engine Series Pin dia B E bore Length B E width
2.0L F20C S2000 early .906" 2.008" 6.023" .935" (from pauter's website)
2.2L F22C S2000 late .906" 2.008" 5.902" .935"
the length difference being f22c is -0.121" which is -3.0734mm
now if the piston is the same that means the piston will stick out of the block 3.6266mm
any thoughts?
Old Aug 15, 2008 | 08:23 AM
ERL_S2000's Avatar
The bore size of the pistons are the same. What is different is the small end of the rod. The placement of the wrist pins are different since the stroke on the F22C is not the same. So due to the rods being different the pistons pin hole placement is different. Hope this helps.
Old Aug 15, 2008 | 11:09 AM
jzz30's Avatar
ok thats what i though the pin height has to be different
Old Aug 15, 2008 | 11:30 AM
jzz30's Avatar
ok so i called inlinepro and they say its the same piston... i hope this works.
Old Aug 15, 2008 | 12:06 PM
inlinepro1's Avatar
The 2.0 liter stroke is 3.307 and the connecting rod is 6.024, the CP Piston is 1.131 compression height. This comes out to 8.808
The 2.2 liter stroke is 3.570 and the connecting rod is 5.895, the CP Piston is 1.131 compression height. This comes out to 8.811
There is only a .003 difference, depending on who manufactures the rods.
The wrist pin in both is a .905
-Chris
Old Aug 15, 2008 | 06:52 PM
jzz30's Avatar
i just realized this. i feel dumb
Clark
Aug 26, 2012 12:19 PM
geared
Jul 10, 2012 08:02 PM
Incubus
Nov 23, 2002 08:27 PM
