Fan Operation Question
Old Jul 5, 2011 | 05:23 PM
dales2000's Avatar
Thumbs up Fan Operation Question
My question is how do the fans work? I know you can set them to come on at a certain temperature but when do they turn off? I am just trying to figure out why my temps rise during highway driving and drop when I exit the highway. I have a haltech PS 1000. and a stock radiator
Old Jul 5, 2011 | 07:56 PM
DFWs2k's Avatar
from what i hear, that means everything is working as it should, you just aren't getting the airflow you need to the radiator.
check the thread re: overheating by o'malley808 in this subforum, and topillogic posted info about what t1 did to his car to get more airflow
Old Jul 6, 2011 | 06:10 AM
dales2000's Avatar
looks like im going to try that. did you end up cutting yours?
Old Jul 6, 2011 | 09:25 AM
DFWs2k's Avatar
im going to lower my intercooler an inch or so and see if that makes it better
Old Jul 6, 2011 | 05:17 PM
camuman's Avatar
u can def control the fans thru an ems. i have mine turn on the moment i start the car. but in the end, this just slows heat soak. if your overheating, bleed the system, try water wetter, maybe cut the bumper. i saw a thread about it and i did it. so far, when moving, i dont see over 185. in bumper to bumper traffic with ac on i saw 207 in 90+ degree heat. i wouldnt worry unless your consistently over 215-220.
Old Jul 6, 2011 | 06:24 PM
dales2000's Avatar
yea i definitely have an air flow problem. If Im doing 80 then my temps start to drop. Im gonna get that cooling plate to see if it helps. I thought about cutting but the cross beam is right above the part of the bumper i want to cut so i doubt it would make much of a difference unless people think other wise....
S2K-OED
Feb 11, 2017 09:03 PM
cesarortiz
Apr 9, 2014 07:31 AM
krnmike
Nov 14, 2008 09:09 PM
pinoyk20
Dec 18, 2007 10:30 AM
124Spider
Jul 13, 2006 10:56 PM
