Fastest S2000's In the World
Ok guys I'm trying to find out on the cars that are in the 9's which ones are FULL WEIGHT? Like my car is full weight no weight reduction and still factory options ac, ps, pw, pl... every option the car came with from the factory.
How much weight could you really lose on this car? If you are running 9's wouldnt you have a roll cage, so some things would have to be removed / plus then the weight of the cage would balance out what you removed etc? Also every xxx lbs is good for what .xx off the 1/4?
Jeremy - Excalibur
ET and MPH: 12.1 @ 123
Turbo/Supercharger: GTX30
Motor: Stock F22
Fuel: Pump 92
WHP: 423
WTQ: 300
Tires: NTO1
Additional Specs: Trackforged Turbo kit with GTX30 option + ID1000 & Fuelpump tuned on Flashpro by Trackforged at 16psi.
Link: Video, timeslip & power graph below.
http://www.youtube.com/watch?v=2Xodg...layer_embedded
Motor: Stock F22
Fuel: Pump 92
WHP: 423
WTQ: 300
Tires: NTO1
S2000GT35-MAXIME
ET and MPH: 11.7 @ 119
Turbo/Supercharger: GT35
Motor: Stock F22
Fuel: Pump 91
WHP: 380
WTQ: 293
Tires: M/T 26X10-15
ADDITIONNEL SPEC: V160 TRANNY AND 8.8 REAR END.
here past link on street tire: http://www.youtube.com/watch?v=kpuE9C-Jfuk
Motor: Stock F22
Fuel: Pump 91
WHP: 380
WTQ: 293
Tires: M/T 26X10-15
10's are just not going to haappen, lol
R/T.........................730
60'.........................1.595
330.........................4.768
1/8.........................7.241
MPH........................101.38
1000........................9.327
ET..........................11.053
MPH...........................132.57
I don't actually, so my 1st to 2nd is what's killing me? I went to 8600 in 1st and just 8300 in 2nd. ( according to my datalog) To be honest, Im not sure where my redline is even set. I should get a shift light
Any recommendations?, also with a shift light, do you set it at the exact RPM where the limit is, or a few hundred before the cut so you don't hit it?
My ignition cut is set at 8,600, and fuel cut is 8,700. What should I set the shift light to?
