FB dual hanger install help!
Old May 28, 2011 | 08:36 PM
Blucky87's Avatar
Default FB dual hanger install help!
So i finally got around to making my fuel lines, got a 100micron fuel filter and got my FB dual hanger installed.. I used the fittings that came with the kit:
^^2 of these go on top, one for the return and one for feed. and then from those is one of these:
and then from that to the -8 and -6 AN fittings and lines.
My problem is that the 90* fitting shown the the first picture for the -8 will not screw down all the way to make a seal and still face in a direction that I am able to attach my -8 hose line.
I am using 90* -8 and -6 an fitting attached to the end of the hoses.
Did everyone else who has a FB kit use the supplied fittings? anyone know the thread type they used on the tops of the hanger? im guessing ntp.
Old May 28, 2011 | 10:26 PM
passmans2kny's Avatar
buy these
http://www.jegs.com/i/Russell/799/612100/10002/-1
http://www.jegs.com/i/Russell/799/612090/10002/-1
Old May 28, 2011 | 11:38 PM
Blucky87's Avatar
thanks! another 50 dollars on fittings
these will fit perfectly? did you use any type of thread sealer?
Old May 29, 2011 | 06:24 AM
they should fit perfect, i actually didnt use these but i wish i did, i used this http://www.jegs.com/i/Russell/799/660863/10002/-1, but i was stupid bc u cant screw in 2 of these with out them hitting each other, so i used one of those on the 3/8 -8 feed, and the brass fitting with on the 1/4 return, i used fuel grade yellow teflon, but if i could do it again i woiuld buy what i suggested in my first post, makes it way easier
MorngWoodStewie
Jul 2, 2017 07:26 PM
liquidgsr
Sep 13, 2012 10:59 AM
