FBM 290lph Fuel Pump/ID1000cc Injectors
Is it possible to reach 600whp with a single 290lph pump and ID 1000cc injectors? TIA
**edit**
I'll be using c16 fwiw
****edit2****
I'm not considering running VP MS109 (unleaded); I'm able to get it locally.
-Kyle
**edit**
****edit2****
-Kyle
I made 501whp with stock fuel pressure with id 1000's and a walbro 255hp and my injector duty cycle was at 98% with e85. At stock fuel pressure id 1000's are good to about 600whp on gas and 500 on e85. a walbro 255 is good for about the same amount. so you should be fine. St the minimum make sure the fuel pump is rewired for power straight from the battery with 12 gauge wire and a relay. To be safe I would just get a adjustable fuel pressure regulator and up the base pressure a few psi higher than stock to keep the injector duty cycle below 90%.
Keep in mind the compression ratio of the motor makes a noticeable difference. I've got a few friends running built 9:1 comp motors with Id1000 and just over 500whp is the max they could get with a 340pump and higher fuel pressures. Lower comp motors aren’t as efficient. I don’t know if the OP is running stock motor or not. I should have noted in last post.
Good info in here. It would also be nice to know the limit with a fb340 id1000s with stock lines on a 2000-2005 with stock engines...
Hmm....if onpy someone knew...haha
Sent from my SCH-I500 using Tapatalk 2
The answers to these questions depends on your definition of "limit". To some people, its when the tune is deemed "unsafe" because it has paramaters above what's regurgitated on the internet. To others, its when the motor blows up on a long high boost pull. Even another definition might be where the motor stops making power at a certain RPM/boost level. What does "limit" mean to you?
