FI ..now which diff
I know this is an issue that has been brought up before but the threads seem old. I am wanting to beef up the differential and have heard the possibility of using a Z32(300ZX) rear end. Also a company called Kaaz manufacters a diff for out car as well. I have yet to see anyone post anything as to whether or not this worked. I know westmiester had some experience in this but seemed some time ago. Any info someone would like to input would be appreciated thanks
I'm not sure about the Kaaz setup, but if you're talking about just an LSD, wouldn't that just be installed in the stock diff casing? If thats the case you may still have a problem with a high power setup... If I'm not mistaken, the stock case is prone to cracking...
with the Z32 rear end you are getting a differential that is in a much stronger case with parts inside that can handle more power...
Or I could be completely wrong...lol someone correct me if necessary please.
Originally Posted by icemans2k02,Aug 14 2006, 11:57 PM
no your right about the nissan diffs they are very strong, i just didnt know if it was true about swapping out the diff that easy. I have heard from a friend locally that inline pro was working on a conversion but found no such product nor post on this
I'm pretty sure that they should be done by now...
yes naveed, your are right
the mount kits are being shipped as of right now, and should be here soon.
you will have to supply your own diff. You'll need a R200 nissan diff. Some come with the LSD, and some don't. Both use the same casing, and will work with our kit. The twin turbo diff WILL NOT work, you must get the non turbo diff.
The kit will go for $2995, and s2ki members will get a price break. Not sure yet, but once i post in the sponsor/group buy forum, you'll find out
http://www.thenissanpartsstore.com/Pages/E....asp?prodId=135
diff right there...
wow i just got owned
diff right there...
I agree, that's a little high with no diff included. So what exactly is included for that price?
