FI weight reduction affect?
Old Jul 20, 2010 | 11:46 AM
ace123's Avatar
Originally Posted by 08s2000CRbackinblack,Jul 19 2010, 12:21 PM
please accept or reject this theory:
i have 426 to the wheel, say roughly double the power over stock. would a 15lb. weight reduction in my car feel like a 30lb. reduction in a stock car????
just wondering because i just weighed my tonneau cover at 11lb. and i figured if i took all the brackets off that'd be about another 3 or 4 lbs. its purely cosmetic and serves no purpose unless the hardtop is off and i am contemplating taking this sucker and and trying to sell it for fund preformance. having the CR, there arent too many items i can strip without ruining the DD ability and comfort it has now.
ANY INPUT IS GREATLY APPRECIATED
So basically, everyone is telling you you're right.
It sounds like your acceleration is what you're asking about. Yeah, you'll get about double the benefit at low speeds because the power to weight ratio will dominate your acceleration performance at low to moderate speeds, assuming you have traction.
However, weight reduction will also improve braking, handling, etc. Of course you don't get to double dip there--you just get a bonus on acceleration.
And using P/W to get an equivalent 2.2whp like vader1 did is a great way to do a reality check on what level of weight reduction will make a noticeable difference. I'd be surprised if you feel more than a placebo level difference without about a 50lb change.
Old Jul 20, 2010 | 07:15 PM
secondhandloser's Avatar
Originally Posted by joefish1298,Jul 19 2010, 04:37 PM
The more power you have, the less the effect of removing weight will have on the power to weight ratio.
Example:
1000kg car with 100kW engine. 10kg per kW. Remove 100 kg, power to weight ratio is now 9kg per kW, an improvement of 1kg per kW.
1000kg car with 200kW engine (twice as powerful). 5kg per kW. Remove 100 kg, power to weight ratio is now 4.5kg per kW, an improvement of only 0.5 kg per kW.
So, removing 15lb from your 426WHP car will feel like removing 7.5lb from a 213WHP (close to stock) car
^ this. it's about the p/w ratio.
Old Jul 21, 2010 | 07:35 AM
leo520's Avatar
if u r 250 pounds , stop eating so much for a few month.. diet till around 150 pounds , n u will gain 0.1 sec faster in the 1/4 miles
Old Jul 21, 2010 | 07:57 AM
camuman's Avatar
on a street car cutting weight is retarded. want more power, add a pound of boost
Old Jul 21, 2010 | 12:11 PM
PsykotiK's Avatar
agreed^^^
Old Jul 21, 2010 | 01:07 PM
dsddcd's Avatar
All you need to know if
F=ma (Force = Mass * Acceleration)
or rearranged
F/m=a (Force / Mass = Acceleration)
Old Jul 21, 2010 | 04:23 PM
IAmTheRealAsif's Avatar
Without getting too into it. If weight it taken off the correct areas on the car its only beneficial. Do what you gotta do
dundeelad02GT
Dec 30, 2008 11:52 AM
Saki GT
Mar 25, 2007 12:26 PM
Hero
Sep 12, 2005 08:49 PM
RUSS2000
Jan 9, 2003 07:24 AM
Rick
Apr 11, 2002 08:01 PM
