Finished PFAB pics...
Old Oct 22, 2008 | 05:08 PM
  #21
GDM S2K's Avatar
Originally Posted by AndyFloyd,Oct 22 2008, 07:51 PM
yea sorry i really didnt mean anything by it. I think the fusebox will be fine, ill be keeping a close eye on it. I wouldnt call myself a beginner since i have owned a turbo car for 5 years now (not a honda). either way, sorry if my comment seemed like a cheap shot, it wasnt meant that way.
we cool homie
Old Oct 22, 2008 | 10:14 PM
  #22
AndyFloyd's Avatar
I had 2 bolts completely back out of the turbo manifold tonight. I am going to go with the stage 8 bolts with the locking ring on top.
Old Oct 23, 2008 | 01:46 AM
  #23
H.A.R.T B18C1EG6's Avatar
i had the same problem. i used loctite and that helped a lot.
Old Oct 23, 2008 | 05:58 AM
  #24
AndyFloyd's Avatar
yeah, i was also thinking of having the bolts tack welded but not sure if ill try that yet. At least its easy enough to remove so it wont take too long.
Old Oct 23, 2008 | 07:39 AM
  #25
8kGoodENuff's Avatar
How much did everything cost you?
Kit?
Drivetrain upgrade?
Andre
Old Oct 23, 2008 | 12:42 PM
  #26
hondabim's Avatar
nice set up, what heat rap did you use on your turbo?
Old Oct 23, 2008 | 03:53 PM
  #27
h22acivicjdm's Avatar
371.5whp 249ft/lb awsome numbers.
post a dyno sheet up.
Old Oct 23, 2008 | 04:02 PM
  #28
AndyFloyd's Avatar
i will, the sheet is at a friends house...left it there on accident. I realized why my bolts backed out, they were metric grade 8.8....yea no good for turbo to manifold bolts. will fix that tonight!
Old Oct 23, 2008 | 04:03 PM
  #29
AndyFloyd's Avatar
summit racing turbine wrap kit. you basically cut it to fit and loop metal wire through both sides to keep it attached.
Old Oct 23, 2008 | 04:06 PM
  #30
AndyFloyd's Avatar
Kit?
Drivetrain upgrade?
Andre
i dunno the total cost, turbo kit + everything else + tune it was prolly in the 9k range honestly. If you use all good parts and do it right its not cheap. The actual kit isnt too bad but its all the other stuff ie ( clutch, wideband, aem, injectors, pump etc ).
i have a stock tranny and diff, hoping to not blow the diff for a while. we will see.
