Finished tapping oil pan now it will not start
Here is the situation a friend and myself installed the Vortech SC over the last few weeks. Yesterday we did tapped the oil and now the car will not start.
At first we put the oil return line just into the oil drain plug, because we did not have everything to do the pan yet and we just wanted to make sure everything else was good. Everything has been running great, we got all the little kinks out and it was great. We did the oil pan yesterday now the car will not turn over. Sounds like its going to start but never sparks or turns over. We did not touch anything electrical only the oil pan.
I thought maybe the plugs were fouled up and they were a little so I pulled them and put new plugs in this morning. No change exact same start.
Any ideas? I am starting to get a little stressed.
It turns over. You can see the drive belts turning and it sounds like it will start but it never fires and keeps turning.
Sounds exactly like a normal start except it doesn't fire and keeps turning...
Originally Posted by Dsgs2k3,Jun 7 2007, 04:23 PM
alright then check the ignition coil fuse under the dash. its prolly blown
Thnx I appreciate the help
