Which fire extinguisher ?
Originally Posted by CoolGuy094' timestamp='1377649537' post='22748330
I would recommend against halon due to its far decreased fire extinguishing capabilities compared to dry chemical. Dry chem extinguishers will leave a mess but they get the job done better/quicker than the same size halon extinguisher. I would much rather give myself the best chance at putting out the fire deal with the cleanup later.
I have to agree.
Any links in which you have?
I keep my extinguisher behind one of the seats. You can also mount it in the trunk with a bracket attached to the cover of the 'secret compartment".
Originally Posted by WootRWD' timestamp='1377649630' post='22748331
[quote name='CoolGuy094' timestamp='1377649537' post='22748330']
I have to agree.
[/quote]
What I was saying is that if you took the same size/weight Halon and Dry Chem extinguishers, according to their ratings the dry chem extinguisher has the capability to extinguish a fire that is much larger in size. Here's a post I made after researching the topic a bit more in another thread:
Originally Posted by petawabit' timestamp='1372272936' post='22632434
do you guys think the 2.5lb or 5lb will be sufficient? i'm thinking this one will be good, since it's also rechargable:
http://www.h3rperformance.com/hg500b.htm
2.5lb Dry Chemical - 1A:10B:C
2.5lb Halotron - 2B:C
5lb Dry Chemical - 3A:40B:C
5lb Halotron - 5B:C
So for the 2.5lb bottles, the Dry Chem has a 10B rating, while the Halotron has only a 2B. That means that the Dry Chem could extinguish up to 5 times as much fire as the Halotron of the same size/weight. For the 5lb bottles the spread is even more... Dry Chem is rated at 40B while Halotron is only rated at 5B... so Dry Chem could extinguish up to 8 times as much fire as the Halotron.
The 2.5lb Dry Chem could extinguish a fire twice the size as one that the 5lb Halotron could extinguish. Smaller bottle, but handles a bigger fire. I don't care if I get yellow powder all up in my car... if its better at putting out the fire then that's the one I want.
Also - the dry chems are rechargeable as well.
thats what i am wondering
