First boost problem =( car wont rev pass 6300
Old May 25, 2007 | 11:18 PM
alleykat's Avatar
Default First boost problem =( car wont rev pass 6300
I've been boosting for a couple of months now with no problems.Until the other day that is.Well Basically my car stops boosting at .5 bars.But the real problem is it wont rev pass 6300rpm's or basically were vtec starts.I checked the aem ems and all the sensors are fine.I switched to a new vtec solenoid and nothing changed.Boost controller is fine and there are no leaks in the piping.I usually run 14psi and haven't had a problem.
My new theory is i might have blown the headgasket.Is it possible for the car to be running after this?
Does anyone else have any other ideas on what may be wrong?
I appreciate new knowledge.Thanks guys.
Old May 26, 2007 | 06:56 AM
geists2k's Avatar
What head gasket?
Does it smoke at all?
Old May 26, 2007 | 07:37 AM
Spec_Ops2087's Avatar
Oil level?
Old May 26, 2007 | 08:00 AM
Asura's Avatar
Check your VTEC settings. With a blown HG car should run the same, just make less power and have the typical symptoms.
Old May 26, 2007 | 08:12 AM
alleykat's Avatar
Car runs fine under 6300-6400rpms.Oil level is fine too.Doesnt smoke constantly just an occasional little puff when pushing the car hard.But whenever vtec is supposed to come in it backfires like if you hit redline
Old May 26, 2007 | 11:23 AM
alleykat's Avatar
bump for answers
Old May 26, 2007 | 12:24 PM
PeanutButter's Avatar
stock map sensor?
Old May 26, 2007 | 12:25 PM
alleykat's Avatar
Nope.I have a 3bar map.I dont think its a boost problem now.Because wouldnt the car keep going regardless of boost?I say its a vtec problem
Old May 26, 2007 | 12:27 PM
alleykat's Avatar
Can this be moved to the proper engine section please.
Old May 26, 2007 | 02:48 PM
All vtec settings ok?
If it starts to backfire sounds like an ignition cut of somekind = tune issue. Double check all the EMS settings
